IPSEC VPN ISSUES - SQL CLIENTS CANNOT CONNECT
tomocisco
Hi All,
Its good to be here once again.
I have set up VPN connection between my head office and a branch office. All the internal systems can ping each other and the phones (VOIP) are working accross the vpn.
The only problem I have is with the Pastel Evolution/Sage (accounting applications) at the branch office which need to access the sql server at the head office. Its giving me error indicating that server is not reachable or access denied.
I can ping the IP address of the server hosting the sql server and I can even remote desktop into the server via the vpn (from the branch ofiice) but the sql clients cannot connect.
Any idea how this can be resolved. The vpn configuration is ok since there is lan to lan connectivity. The config for head office is shown below:
#sho run
Building configuration...
Current configuration : 4079 bytes
version 12.4
boot-start-marker
boot-end-marker
enable secret 5 $1
no aaa new-model
clock timezone utc 1
crypto pki trustpoint TP-self-signed-3885639516
enrollment selfsigned
crypto pki certificate chain TP-self-signed-3885639516
certificate self-signed 01
ip cef
ip domain name master.com
ip name-server 4.2.2.2
password encryption aes
crypto isakmp policy 1
encr aes 256
hash md5
authentication pre-share
group 2
crypto isakmp key ccc address y.y.y.y
crypto ipsec transform-set ME-VPN esp-aes 256 esp-md5-hmac
crypto map VPN-TO-PH 10 ipsec-isakmp
description SET PEER TO PH IP ADDRESS
set peer y.y.y.y
set transform-set ME-VPN
match address VPN-TRAFFIC
archive
log config
  hidekeys
class-map match-any P2P
match protocol bittorrent
policy-map P2P
class P2P
   drop
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
service-policy input P2P
interface FastEthernet1
ip address x.x.x.x 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet2
interface Vlan1
no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.1
no ip http server
ip http secure-server
ip nat inside source route-map LAT interface FastEthernet1 overload
ip access-list extended VPN-TRAFFIC
permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 remark EXCLUDED FROM NAT
access-list 100 deny   ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
route-map LAT permit 1
match ip address 100
control-plane
end
Thanks for your times.
Tom
Giuseppe Larosa
Hello Tom,
Check the MTU from clients in remote office to sql server with a ping test
Check if the server is running a software firewall or the sql sever has any settings describing the IP subnets of allowed clients.
Hope to help
Giuseppe
