06-04-2008 09:59 PM 03-03-2019 10:14 PM 更新
In one of our 1841 router I have configured IPSEC VPN's and having some issues while routing the traffic. The primary link will be Vlan 10 and secondary will be Cellular 0/0/0 interfaces and IPSEC is configured on both. For routing i am using OSPF for the primary path and a default route with higher AD pointing the Cellular interface for the secondary link when the primary fails.
The problem is, when the primary link fails the secondary link comes up and for some reason the traffic is not getting routed via the Cellular interface link. When I remove the VPN configs from the primary interface the traffic is getting routed via the cellular link and every thing is ok. I know if i use two subents for local lan and the primary links the issue will be fixed, but unfortunately i can't do that.
I guess some one will able to help me out to fix this issue. I have attached a diagram which might be helpful.
Rajesh
06-05-2008 07:53 PM
Rajesh,
Could you post the configuration excluding sensitive information?
Thot
06-10-2008 10:28 PM
Hi there,
I have pasted my configs below.
interface FastEthernet0/1
shutdown
interface FastEthernet0/1/0
switchport access vlan 10
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Cellular0/0/0
ip address negotiated
ip access-group IPSec-Filters-In in
ip access-group IPSec-Filters-Out out
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string gsm
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxxxxx@xxxxxxxxxx.rdsl
ppp chap password xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
crypto map VPN-MAP
interface Vlan 10
ip address 10.10.10.2 255.255.255.240
ip helper-address 10.10.100.1
ip helper-address 10.10.100.2
ip helper-address 10.10.100.3
no ip redirects
no ip proxy-arp
duplex auto
speed auto
no mop enabled
crypto map VPN-MAP
router ospf 1
log-adjacency-changes
network 10.10.10.0 0.0.0.15 area 0
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 200
The router will be getting a default route when its connected via primary link through OSPF.
Rajesh
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
