IPT for remote users
jamilakhtar
Hi there,
Can any ones suggest the cheapest implementation of IPT for home users please.
6 Replies 6
paolo bevilacqua
A free softphone and a free softswitch.
I have 250 home users. We have IPT in the offices and now planning to have IPT for home users as well. we will get them IP phone and I was thinking of using Draytek routers with QOS feature. Do you think that will be sufficient.
Best Regads,
Which model of Draytek router?
Vigor2800v.
avmabe
Level 3
Level 3
Well... Not the cheapest but works perfect based on our requirements....
We have home users with Macs... so softphone was not an option.
I have a 3000 VPN Concentrator and remote there are PIX501's with the 7940 phone hanging behind the pix. I use a split tunnel and it also allows home users access to the internal LAN so they don't need a VPN client anymore.
Cheap? No. Secure? Yes. Scalable? Yes.
Thanks a lot for ur kind assistance.
regards,
Jamil
