IPv6 stateless configuration does not work
aparikh
I am trying to configure the Cisco 7603 as a IPv6 stateless DHCP server & 7204 as client. I am not sure what I am missing in the configuraton.
Following are the configuration from 7603:
interface GigabitEthernet3/1
no ip address
ipv6 address FE80::1 link-local
ipv6 enable
ipv6 nd other-config-flag
ipv6 dhcp server dhcp-pool rapid-commit
end
Cisco 7204
no ip address
ipv6 address DH-PREFIX 0:0:0:1::/64 eui-64
ipv6 enable
end
Harold Ritter
You first need to change the following command on the client router:
to
ipv6 dhcp client pd DH-PREFIX rapid-commit
Did you configure your dhcp pool on the server side?
Also, I don't think you can dinamically get a prefix for gig3/1 since it is the interface on which you configured the "ipv6 dhcp client" command.
Hope this helps,
I am using Stateless DHCP configuration. Following is my modified configuration. This configuration is from the Cisco Ipv6 Configuration guide.
1. I turned on the debug ipv6 dhcp command & I do not see any DHCP packet from Client or server.
2. How do you configure the server with the certain prefixes to advertised?
7603 (DHCP Stateless Configuration)
ipv6 dhcp pool dhcp-pool
dns-server 2001:DB8:A:B::1
dns-server 2001:DB8:3000:3000::42
domain-name verybigcompany.com
interface G3/1
description Access link down to customers
ipv6 address 2001:DB8:1234:42::1/64
7204 (Client Configuration)
interface G0/1
description Access link up to provider
ipv6 address autoconfig
