IPV6
s4sandyad
Hi Frndz,
i am learning IPv6...
confused in between link local address & EUI-64 address..
how they are self generated.. what is logic behind them..
Plzz help me to understand difference between them.
Sandy
Krishnendu AR
Link local address is used to communicate within that link only. It can't travel more than a single hop.
This is how the link local address is found out:
fe80::MAC(fffe) address. fffe is inserted in between mac address. Then invert the 7th bit of mac address. Lets check in details.
R1#sh int fa0/0 | i bia Hardware is AmdFE, address is cc03.0c98.0000 (bia cc03.0c98.0000)
cc03.0c98.0000 is the mac address.
So the link local address would be fe80:cc03.0cff:fe98.0000. Now I have to invert the 7th bit.
cc03.0c98.0000: converting first 2 nibbles to binary c=1100
1100 1100 03:0c98.0000 . Inverting the 7th bit
1100 1110 03:0c98.0000 .
Converting 1100 1110 03:0c98.0000 back to hex: ce03:0c98.0000
So the final link local address of that interface  would be fe80::ce03:0cff.fe98.0000
EUI-64 also use the same logic to generate a 128bit unique global unicast IP address when we provide a /64 prefix. The remaining /64 is found out using the above mentioned logic.
Krishna
Krishnendu AR
Krishna
s4sandyad
Thanx Krishna....
Can u please tell me how to implement EUI-64 ip addressing in network....
what to do on Xp, win 7 machines to get ipv6 by using EUI-64 ...
S@ndy...
