IR1101 not able to login ,not able to reset to factory default
i received an cisco IR1101 i started the router after finding a power supply, and the credentials doesnt work. Did not handle by me all of this time.
the reset button doesnt work , i pressed 20 seconds but nothing happend.
do you have any suggestions on how can reset the config?
