IR829 SIM Card Slots
John.Barbour
I have an IR829 that I am doing testing with and I have a question as to the capabilities of the SIM cards slots. Can both of these be bonded together to create greater throughput, or are they used in a fail over capacity only? When slot 0 loses connectivity slot 1 connects and so on. I do  not know a whole lot about cellular technology, so any help would be greatly appreciated.
Hello John,
the short answer is: SIM card slot bonding is not possible. By default, slot 0 is the primary, and slot 1 the backup.
You can have a look at the link below for details:
Configuration of Dual SIM Feature and SIM Failover
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/lte-wireless-wan-interfaces/200455-Configuration-of-Dual-SIM-Feature-and-SI.html
