01-02-2013 07:41 AM - edited 03-04-2019 06:33 PM
Is the 7600-SIP-400= & SPA-1XOC12-POS still supported in the old models of the Cisco 7609 i.e.;
Solved! Go to Solution.
01-02-2013 08:10 AM
Product Specifications of Cisco 7600 SIP-400
Compatibility
Cisco Route Switch Processor 720 3C/3CXL, Cisco Supervisor Engine 720-3B/3BXL, and Cisco Supervisor Engine 32 (Sup-32) systems
Minimum software compatibility
Cisco IOS® Software Release 12.2(18)SXE, or later releases for Supervisor Engine 720-3B/3BXL and Supervisor Engine 32 systems in native mode Cisco IOS Software; also, 12.2(33)SRB or later releases for RSP720-GE-3CXL and RSP720-GE-3C systems
http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8027c9e6.html
Raju
01-02-2013 08:10 AM
Compatibility
Raju
01-07-2013 05:00 AM
01-07-2013 05:16 AM
Yes. But that line has come under Physical specifications.
I can confirm you that SIP400 will work with SUP32
RAju
01-07-2013 05:22 AM
Thanks.
01-07-2013 05:31 AM
You are welcome
Raju
