Is a ACE10-6500-K9 supported on Cisco 7609-S?
exchange1
Is it possible to use a Cisco ACE10-6500-K9 on a Cisco 7609-S with route processor RSP720-3CXL-GE (c7600rsp72043-advipservicesk9-mz.122-33.SRB2.bin and 7600-PFC3CXL)? If yes, what other cards are required?
Giuseppe Larosa
Hello Olaosebikan,
according to HW support for C7600 the answer is yes but starting with IOS 12.2(33)SRC
see
http://www.cisco.com/en/US/docs/routers/7600/Hardware/12.2SR_supported_hw/7600_hwd.html#wp1273283
You should need an IOS upgrade, no additional cards should be needed (no DFC just to make an example)
Hope to help
Giuseppe
