12-20-2018 04:22 PM
I'm trying to enable SSH and secret but I seem to be missing some commands.
I set the domain-name to see if that would enable it but still no go.
I don't seem to have the crypto command available.
The secret command isn't available when I try to create a user only password.
Is this a version issue and can I upgrade the firmware or am I missing something that needs to be done to enable it?
I have a Cisco 7120-T3 Version 12.1(5)T10
Joel
Solved! Go to Solution.
12-21-2018 04:47 AM
12-21-2018 04:47 AM
12-21-2018 10:43 AM
I don't seem to have anything with ipbase. So maybe that means that SSL is out.
Router#sh version
IOS (tm) EGR Software (C7100-IS-M), Version 12.1(5)T10, RELEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Tue 07-Aug-01 20:23 by ccai
Image text-base: 0x60008960, data-base: 0x61620000
ROM: System Bootstrap, Version 12.0(5r)XE2, RELEASE SOFTWARE (fc1)
BOOTFLASH: EGR Software (C7100-BOOT-M), Version 12.0(5)XE7, EARLY DEPLOYMENT RE)
Router uptime is 20 hours, 36 minutes
System returned to ROM by reload at 14:00:10 PST Thu Dec 20 2018
Running default software
cisco 7120-T3 (EGR) processor (revision A) with 57344K/73728K bytes of memory.
Processor board ID 11509649
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 1 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
12-21-2018 11:29 AM
I see these when I do dir
Router#dir bootflash:
Directory of bootflash:/
1 -rw- 2814896 May 15 2000 08:35:26 c7100-boot-mz.120-5.XE7
Router#dir /all disk1:
Directory of disk1:/
3 -rw- 9188664 Feb 22 2003 00:24:06 c7100-is-mz.121-5.T10
