Is it best practive to Use or don't use IP REDIRECTS for a tunnel
CiscoBrownBelt
Level 6
Level 6
Should I disable IP REDIRECTS for security reasons? The thing is, is that I am using EIGRP for routing as well.
Julio E. Moisa
I agree with Reza, it should be disabled to avoid any malicious user can be sending packets to a router.
no ip redirects under the interfaces.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
5 Replies 5
Reza Sharifi
Best security practice is to disable it
no ip redirect
Ok thanks for the info!
You are welcome  :-)
Please don't forget to rate the comments if they are useful it will help to other members in a future. Thank you in advance.
Have a good day.
Julio E. Moisa
