Is my 877 forwarding all IP packets?
cmorley
Hi, the adsl router does a simple NAT from the WAN ip to LAN ip 10.0.0.2. All packets then goto our firewall. I know IP TCP/UDP is being forwarded ok, but could someone kindly check the access list and confirm all IP packets are being forwaded as i wish to allow GRE tunnel (IP protocol 47) packets through also. Config below:
interface Vlan1
ip address 10.0.0.2 255.255.255.0
ip nat inside
interface Dialer0
ip address negotiated
ip nat outside
ip route 0.0.0.0 0.0.0.0 Dialer0
ip nat inside source static 10.0.0.1 interface Dialer0
access-list 110 permit ip 10.0.0.0 0.0.0.255 any
dialer-list 10 protocol ip permit
Many thanks
Chris
Access lists can be applied either In or OUT of an interface using ip access-group command.
ip access-group 110
check this URL to get more information.
http://www.cisco.com/warp/public/707/confaccesslists.html#sourcedefine
ACL is used to filter traffic, but ACL 110 is permitting everything so it is as good as using no ACL.
HTH, rate if it does ...
sourabhagarwal
Level 4
Level 4
have you put complete configuration of vlan 1 and dialer 0?
per your config, i don't see ACL 110 applied to any interface, neither I see use of dialer list 10 in the config.
if this config is working for you, as ACL is not applied to dialer 0 or VLAN 1, no traffic will be blocked. Even if ACL is applied on any interface, it won't block anything coming from 10.0.0.0/24 network as you are permitting all IP traffic.
also you have configured static NAT for only 10.0.0.1, so there will not be any NAT translations for other IPs.
hope this answer your query. rate if it does ...
let us know if you are looking for something else.
Thanks for the quick reply. Full config below, passwords removed!
version 12.4
no service pad
service password-encryption
hostname xx
boot-start-marker
boot system flash c870-advsecurityk9-mz.124-4.XC4.bin
boot-end-marker
no aaa new-model
resource policy
ip cef
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/50
encapsulation aal5snap
protocol ppp dialer
dialer pool-member 5
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip nat inside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
ip tcp adjust-mss 1300
no ip mroute-cache
interface Dialer0
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 5
dialer remote-name Etisalat
dialer-group 10
ppp chap hostname test
ppp chap password 7 test
ppp pap sent-username test password 7 test
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
transport output all
line aux 0
line vty 0 4
privilege level 15
login local
transport input ssh
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Not that i want to in this case and out of curiosity, how would you apply the ACL to interface?
Chris
ip access-group 110
