01-05-2006 04:45 AM - edited 03-03-2019 11:22 AM
Reason - remote router has 2 equal routes for a desitnation network, but we want to influence traffic over a specific router. We have changed the delay value on the remote routers inbound interface, but the delay value is not being seen on the local router and is keeping 2 equal cost paths.
Solved! Go to Solution.
01-10-2006 03:46 AM
Hello Paresh,
The offset-list did the trick.
One last question, does the ip summary-address influence (negate) the delay statement in any way? Reason I ask is, my predecessor believed that without the ip summary-address, the delay statement worked and we did not need the offset-list.
Thanks in advance for all your help.
01-10-2006 03:55 AM
The 'ip summary-address' command and the 'delay' statements are completely independent. I have no idea why your predecessor would have believe that there was a relationship between them.
Hope that helps.. pls rate posts that are helpful.
Paresh.
