is this a valid setup?
Hi Everybody,
I tried to ping 192.168.1.2 to 192.168.1.1 but does not ping. Just wondered if its a valid setup.
Please let me know if there is any config mistake or any aditional config is required. Any link to understand froming etherchannel on a vlan will also be helpful.
Ravi
Hi Ravi
try the bellow config with simple changes
hostname multi_switch
vlan 10
name Vlan_10
interface FastEthernet0/1
channel-protocol pagp
channel-group 1 mode desirable
switchport access vlan 10
interface FastEthernet0/2
interface FastEthernet0/3
interface Port-channel 1
no shut
interface Vlan1
no ip address
shutdown
interface Vlan10
no shut
hostname Switch
vlan 10
name Vlan_10
channel-group 1 mode auto
no shut
Good luck
14 Replies 14
lgijssel
Level 9
Level 9
This is certainly a valid setup.
Problem may be with you port channel configuration but recently there was a similar "cannot ping" problem in which the windows firewall was the culprit. This could be the case here as well.
Config info for etherchannel:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_4_ea1/configuration/guide/swethchl.html
regards,
Leo
johnlloyd_13
Level 9
Level 9
hi ravi,
try to replace trunk links between switches with cross-cables (represented as dashed lines) and test again.
Marwan ALshawi
Make the etherchannel based on the protocol either
Auto desirable
Or
Auto active
Make sure you etherchannel is up
Show etherchannel summary
I will paste the configure again and paste the config and the results. My collegues say its not a valid setup but thanks now I know its a valid set up.
Ravi
Hi All,
Please find the config below:
L3/multilayer (still being used in l2)
interface Vlan1
no ip address
shutdown
interface Vlan10
ip classless
Switch
hostname Switch
interface FastEthernet0/4
PC IP : 192.168.1.2/24
Now, is there any config issue in this?
Still unable to ping...below is the ether channel summary:
On multiswitch:
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)           PAgP   Fa0/1(P) Fa0/2(P)
On nomal l2 switch:
i am not able to figure out where exactly is the issue.
Regads,
Ravi
Hi Ravi
vlan 10
name Vlan_10
no shut
interface Vlan1
no ip address
shutdown
interface Vlan10
no shut
hostname Switch
vlan 10
name Vlan_10
no shut
Good luck
Hi Marwanshawi,
Let me give it a go and let you. Keep you updated.
Ravi
pls check is this config required under interface ?
#switchport access vlan 10
No mate. adding the vlan in the portchannel did not help.
Ravi
Guys,
It did not work. I have been trying this. Till now no luck. I have tried all the above. Not working.
Any assistance will be hightly appreciated.
Ravi
Ravi,
Can you please post the output of the show etherchannel summary from both switches? Thank you!
Best regards,
Peter
Hi Peter,
multilayer
Normal:
Please do let me know if you need any other information.
Ravi
Ravi,
Neither me nor other friends here have spotted a problem, and this is really a very basic configuration. If you are trying to configure this in Packet Tracer, be warned that the Packet Tracer may not be simulating this kind of configuration properly. In that case, we are trying to find a bug where none exists. Do you have an option of testing this on a real equipment?
Best regards,
Peter
Hi All,
It works fine. I just need to wait 5 sec before I can start pining. I think adding the vlan to the portchannels resolved the issue.
Thanks All.
Cheers!
Ravi
