Is this a valid setup
Hi All,
I wanted to know if this should work
l3 switch(f1/0) --->(trunk)--->(f0/0)  L2switch   (f0/1) ------>(vlan 10)---->pc
On the l3 siwtch:
interface FastEthernet1/0
switchport mode trunk
interface Vlan10
ip address 192.168.10.1 255.255.255.0
  exit-vlan-config
On l2 Switch
interface FastEthernet0/0
interface FastEthernet0/1
switchport access vlan 10
On PC I gave ip 192.168.10.2
Question: Should I be able to ping the vlan 10  interface ip address from the PC?
Ravi
Jon Marshall
Ravi
Yes you should. Make sure you have created the vlans at L2 on both switches ie.
switch(config)# vlan 10
switch(config-vlan)# name v10
you can check that the vlan exists at L2 by running the "sh vlan brief" command on both switches and you should see vlan 10 in the vlan database.
If you have more than one L3 vlan interface on the L3 then make sure you enable ip routing ie.
switch(config)'# ip routing
Jon
Jon Marshall
Ravi
Jon
Hi Jon,
I was using 3460 in GNS3 as my l2 swich. Thanks, I missed to add the vlans on the l2. So searched on google on how to add vlans on 3460. Now I can ping the vlan interface on 3460 l3 switch.
en
vlan database
vlan 10
apply
exit
Ravi
