03-05-2016 01:51 PM - edited 03-05-2019 03:29 AM
Is this combination is correct on a c7606 SIP-400 + SPA-1X10GE + SPA-2XOC12
My IOS is c7600rsp72043-advipservicesk9-mz.152-4.S2.bin
When I've inserted the SPA-1X10GE then it says
%SIPSPA-4-MAX_BANDWIDTH_NS: Total SPA bandwidth exceeds line card capacity, installed combination of SPA interfaces is not supported
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6700-DFC3CXL SALxxxxxxxxxxx 1.6 Ok
2/1 2xOC12 POS SPA SPA-2XOC12-POS SALxxxxxxxxxxx 1.0 Ok
2/2 1x10GE XFP SPA SPA-1X10GE-L-V2 SALxxxxxxxxxxx 1.5 AdmnDown
Mod Online Diag Status
1 Pass
2 Pass
2/1 Pass
2/2 Not Applicable
5 Pass
Antra
03-07-2016 12:31 AM
Troubleshooting Oversubscription on the Cisco 7600 SIP-400
As of Cisco IOS Release 12.2(18)SXF, when using the Cisco 7600 SIP-400 with the 2-Port Gigabit Ethernet SPA or the 1-Port OC-48c/STM-16 ATM SPA, consider the following oversubscription guidelines:
•The Cisco 7600 SIP-400 only supports installation of one 1-Port OC-48c/STM-16 ATM SPA without any other SPAs installed in the SIP.
•The Cisco 7600 SIP-400 supports installation of up to two 2-Port Gigabit Ethernet SPAs without any other SPAs installed in the SIP.
•The Cisco 7600 SIP-400 supports installation of any combination of OC-3 or OC-12 POS or ATM SPAs, up to a combined ingress bandwidth of OC-48 rates.
•The Cisco 7600 SIP-400 supports installation of any combination of OC-3 or OC-12 POS or ATM SPAs up to a combined ingress bandwidth of OC-24 rates, when installed with a single 2-Port Gigabit Ethernet SPA.
Configurations on the Cisco 7600 SIP-400 with an unsupported aggregate SPA bandwidth greater than OC-48 rates generates the following error message:
SLOT 3: 00:00:05: %SIPSPA-4-MAX_BANDWIDTH: Total SPA bandwidth exceeds line card capacity of 2488 Mbps
03-08-2016 04:09 AM
Thank you for your answer.
So if the limit is OC-48(2Gbps), then why it support the 10Gigabits.
What should be the SIP used if we want to use this 10Gigabits?
Otherwise what should be done if we want to add another STM-16.
Antra
