Anup Sasikumar
Beginner
Is VPER and HSEC license BOTH required for Cisco 1111-4P to have 150Mbps Crypto throughput
Is VPER and HSEC license BOTH required for Cisco 1111-4P to have 150Mbps Crypto throughput ?
Please suggest.
Anup
Anup
1 REPLY 1
cesahern
Yes, the default crypto throughput of the series 1000 routers are 50 Mbps, with the license "seck9" you can have services like IP Base + Advance Security: Zone-Based Fireall, IPSEC VPN, ExVPN, DMVPN, GETVPN, FlexVPN with the same default crypto throughput. Then the "VPER" license increases this crypto throughput to 100 Mbps for the C1100-4P and 200 Mbps for the C1100-8P
    https://gzhls.at/blob/ldb/2/2/f/4/7370cc0a47596eb6617777986a03fd943e3a.pdf
On this routers you can see the current crypto throughput with the command:
sh platform hardware throughput crypto
    https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-7/cisco_1100_series_swcfg_xe_16_7_x/cisco_1100_series_swcfg_chapter_0111.html?referring_site=RE&pos=4&page=https://www.cisco.com/c/en/us/support/routers/1110-integ...
