Is WPA or WPA2 possible in a 877w?
whiteford
Beginner
Beginner
Hi, I have just received a Cisco 877w and it is configured to use WEP. I was wondering if it possibel to use WPA or even better WPA2?
Here is the wireless config:
interface Dot11Radio0
no ip address
encryption key 1 size 128bit 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxx transmit-key
encryption key 2 size 128bit 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxx
encryption key 3 size 128bit 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxx
encryption key 4 size 128bit 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxx
encryption mode wep mandatory
ssid mynet
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 1
What would I need to change, it seem the VLAN1 is bridged across to the BVI1 interface?
Hi mate
Can you send me through your email address, and I will email you the config from my home 877w.
Martin
6 Replies 6
Martin Parry
Participant
Participant
The 877W will support WPA. Try something like this:
dot11 ssid mynet
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 1411145255012F737C2C376275100440550354585906005D5149
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid mynet
station-role root
bridge-group 1
Do I not use the "interface Dot11Radio0"
I see you use "dot11 ssid mynet"?
Does it matter if I bridge the Vlan1 or Bvi1?
Sorry for the delay in getting back to you, I was travelling home, and only just picked up your post.
Int Bvi1 will be the logical interface for your bridge-group 1. You will assign the IP address for your Vlan 1 / wireless network to this interface. You will assign both the interface vlan 1 and interface dot11Radio0 to this bridge-group.
Create the dot11 ssid mynet globally, and apply the authentication commands etc to this, then under int dot11Radio 0 you will assign this ssid, and the encryption method you are going to use. I just put AES in as an example.
Hope this helps
Martin
Thanks Martin, just got into work to pick this up.
Do you have an example on how this might look in the config? I'm use to 837,877's and etc in CLI but this wireless side has confused me :)
What's confusing is I use "interface Dot11Radio0" where my ssid is, but what is this new "dot11" ssid name etc?
Sorry for the questions, is the bvi the interface for the wireless users and the vlan1 just for ethernet users then?
Thanks in advanced Martin.
Hi mate
Martin
Hi Martin, just sent you an email to your above address.
