ISDN Backup
hello gentlemen,
i have the following question,
i have an 876 adsl router with an isdn backup interface.
im having difficulty making the backup interface work.
i am posting a partial config below so you can see what the deal is.
i would really appreciate any and all help. this is a pressing matter for me, ive tried many different ways, including dialer maps. calling sos!!
interface BRI0
description BACKUP ISDN
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
encapsulation ppp
no ip split-horizon
dialer pool-member 2
isdn switch-type basic-net3
isdn point-to-point-setup
no cdp enable
interface ATM0
backup interface Dialer1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description WAN LINK
no snmp trap link-status
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description LAN LINK
ip address 192.168.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 2
no cdp enable
ppp authentication pap chap callin
ppp chap hostname **********
ppp chap password 7 010507404F0A54
ppp pap sent-username ******** password 7 15040A48102B79
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username **************** password 7 044D0A421B201E
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 192.168.10.1 1723 ********************* extendable
ip nat inside source static udp 192.168.10.1 1723 *********************extendable
ip nat inside source static tcp 192.168.10.1 25 ********************* extendable
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
no modem enable
line aux 0
line vty 0 4
transport input telnet ssh
line vty 5 15
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
webvpn context Default_context
ssl authenticate verify all
no inservice
end
shillyar
under your BRI interface you have dialer pool member 2.
That points to interface dialer 2 and I do not see a dialer interface 2 in your conf. Try that and see what happens.
Thx Steve
smothuku
Level 7
Level 7
interface BRI0
encapsulation ppp
interface ATM0
backup interface bri0
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 1
no cdp enable
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-lsit 1 protocol ip permit.
Do the above changes and check the issue..Leave the nat commands configured as it is..
satish
Hello
Change the dialer interface to d2 instead of d1
Thx Steve
