ISDN BRI PRI
zanub
Can anyone post a configuration for ISDN Bri 7 remote sites dialing a central PRI location with dialer string in the remote site.Is there a need to create dialer in the main site.Is this configuration fine.
Main site
interface Serial2/0:15
ip unnumbered Loopback0
encapsulation ppp
isdn switch-type primary-net5
dialer idle-timeout 300
dialer-group 1
Remote site
interface BRI0/0
encapsulation ppp
ip ospf demand-circuit
dialer string 123456
dialer-group 1
isdn switch-type basic-net3
I want to use ospf as well. Can a web based application bring the link up? Will the PRI module assign bandwidth as required by the BRI sites or it is necessary that i configure ppp multilink to get the full 128kbps
AFAIK you need to have the ip ospf demand circuit command keyed only on one side of the connectivity.
As you have done in the remote bri location in your case .
The main idea behind this command is to suppress the periodic updates which can trigger out and flood the bri links..
regds
13 Replies 13
spremkumar
Level 9
Level 9
you need to configure the following command at the central site to have 128K(2B channels) alloted for each location.
ppp multilink
multilink max-links 2
in the remote location also u need to enable multilink and also dialer load-threshold command to trigger the second channel once u see some traffic on the first channel.
Also check out for the interesting traffic which u configure up in the dialer list so that it can trigger the call.
Also refer this link for more info in configuring up the same..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca71d.html
Have seen most of the configs only with dialer interface especially which are involving PRI cirucitry and serving remote dial ins..
regds
Thanks prem. Isn't dialer interface just for dialing.I had configured 1 dialer interface for one site in the PRI Main site, in this case the PRI was assigning one dialer interface for 1 call ie incoming. I could see that in the routing table which says if this network go to dialer x.So should i configure double the dialer interfaces and use the commands you advised or will PRI assign mannually.Do you configure seperate dialers for each location in the main site. Isn't dialer just a virtual interface used inorder to dial multiple locations.
i feel this link will help u out in getting ur config done for both dialout and dialin from the same PRI circuit..
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080094559.shtml
regds
Will this configuration give me 128kbps bandwidth. Should i configure dialers in the bri router or create multilink groups.
Pri router
encapsulation ppp
dialer pool-member 1
ppp multilink
interface Dialer8
description Connected To xxxxxxx
encapsulation ppp
dialer pool 1
dialer caller xxxxxx
dialer-group 1
interface Dialer9
encapsulation ppp
dialer pool 1
dialer-group 1
Bri router
interface BRI0/0
encapsulation ppp
dialer idle-timeout 900
dialer string xxxxxx
dialer-group 1
ppp multilink
dialer load-threshold 1
Do configure ppp multilink under the dialer interface which you have configured up over there in the Central Location (Pri Router) and chek.
regds
I tried it.Still not working.Should create a multilink interface?
I have finally got both channels up. I want to know if there is any problem in ip ospf demand circuit command. As of now dials are disconnecting after idle timeout. I have configured the command only in the remote bri locations.
regds
Thanks for the reply. I have given a default route in the remote router, what other traffic should i be blocking.
hi
Can you revert using the dialer-list whether you have allowed any particular interesting traffic to trigger out the bri line or by permitting all the traffic ?
regds
I've permitted all ip traffic.
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
Also have a static route. I have OSPF. So can i remove the static route. It should work fine right. I want to know if the dialer would dial even if there are no entries on the routing table( will ospf entries be retained even after switching off with the OSPF demand circuit command.)
Thanks for the inputs on ISDN. Hope you don'e mind helping on another topic too.
I have to get E3 oonfigured end to end.I'm going to use all the E1 channels for the same network. So should i configure one multilink group and add all interfaces to that group or is there any way i can configure one single ip address for all the e1 channels to act as one e3 channel.
controller E3 9/0/0
e1 1 channel-group 0 timeslots 1-31
e1 2 channel-group 0 timeslots 1-31
e1 3 channel-group 0 timeslots 1-31
e1 4 channel-group 0 timeslots 1-31
e1 5 channel-group 0 timeslots 1-31
e1 6 channel-group 0 timeslots 1-31
e1 7 channel-group 0 timeslots 1-31
e1 8 channel-group 0 timeslots 1-31
e1 9 channel-group 0 timeslots 1-31
e1 10 channel-group 0 timeslots 1-31
e1 11 channel-group 0 timeslots 1-31
e1 12 channel-group 0 timeslots 1-31
e1 13 channel-group 0 timeslots 1-31
e1 14 channel-group 0 timeslots 1-31
e1 15 channel-group 0 timeslots 1-31
e1 16 channel-group 0 timeslots 1-31
e1 1 framing no-crc4
e1 2 framing no-crc4
e1 3 framing no-crc4
e1 4 framing no-crc4
e1 5 framing no-crc4
e1 6 framing no-crc4
e1 7 framing no-crc4
e1 8 framing no-crc4
e1 9 framing no-crc4
e1 10 framing no-crc4
e1 11 framing no-crc4
e1 12 framing no-crc4
e1 13 framing no-crc4
e1 14 framing no-crc4
e1 15 framing no-crc4
e1 16 framing no-crc4
i cant find the card type command or the serial interfaces in running config
Thanks in Advance
