ISDN error
hannyong
*Mar 2 20:46:56.293: ISDN **ERROR**: Module-CCPRI Function-CCPCC_CallRoutingIn Error-Unknown event received in message from L3 or Host: 58
Anyone seen the above or know where do I start looking? Thanks in advance
Richard Burts
Hann
I tried to find this with the Error Message Decoder from the Cisco web site but it did not find anything about it. I also did some searching on the Cisco site and did not find anything.
If you have a service contract on this router I would suggest opening a case with Cisco TAC.
Rick
Rick
Hi Rick,
Yeah, I did some search too, but couldn't find anything. So far, it seems like an ISDn event msg. It's not affecting anything at the moment, and it only appears during a debug isdn q931. I'm just waiting to see if anyone had similar problems before.
smothuku
Level 7
Level 7
Hi ,
Found the below info from Cisco...
CSCeg20283
Symptoms: E1R2 SS7 calls fail to come up when more than one call is made with the following ISDN error:
ISDN Se1/6:15 SC **ERROR**: call_connect: call_id not found, rejecting call ISDN **ERROR**: Module-CCPRI Function-CCPCC_CallConnected Error-Unknown event received in message from L3 or Host: 4F
Conditions: This symptom is observed on a Cisco platform that runs Cisco IOS Release 12.3(11)T.
Workaround: There is no workaround.
better go for different image.
http://www.cisco.com/en/US/docs/ios/12_4t/release/notes/124TCAVS.html
Satish
Hi Satish,
I did saw that bug during my research, but I see it linking to E1R2 and using SS7. My setup is pure basic H323 with ISDN PRI.
