isdn layer3?
jay77jay77
Im having problem establishing a remote isdn bri site to establish the call to HQ.
I can see that when i do the " clear int bri 1/0" the layer 1 active and layer 2 mutiple frames established.
however when i try to do a test call " isdn test int bri 1/0 xxx" the call fails with error " service/option unspecified.
Here is the debug q931 output:
Jan 25 23:19:09.913 UTC: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 0xxx
Jan 25 23:19:09.913 UTC: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x7A
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Called Party Number i = 0x80, 'xxxx'
Plan:Unknown, Type:Unknown
Jan 25 23:19:10.205 UTC: ISDN BR0/1/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0xFA
Channel ID i = 0x89
Jan 25 23:19:10.205 UTC: ISDN BR1/1 Q931: RX <- SETUP_ACK pd = 8 callref = 0xFA
Channel ID i = 0x89
Jan 25 23:19:10.641 UTC: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xFA
Jan 25 23:19:10.641 UTC: ISDN BR1/1 Q931: RX <- CALL_PROC pd = 8 callref = 0xFA
Jan 25 23:19:10.737 UTC: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xFA
Cause i = 0x82BF - Service/option not available, unspecified
Jan 25 23:19:10.737 UTC: ISDN BR1/1 Q931: RX <- DISCONNECT pd = 8 callref = 0xFA
Jan 25 23:19:10.741 UTC: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8 callref = 0x7A
Cause i = 0x80BF - Service/option not available, unspecified
Jan 25 23:19:10.937 UTC: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xFA
Jan 25 23:19:10.937 UTC: ISDN BR1/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xFA
Jan 25 23:19:12.929 UTC: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 111 changed to down
Jan 25 23:19:12.937 UTC: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Appreciate any advice!
tks
Jay
Richard Burts
Jay
On Jan 25 you posted exactly this same question on the LAN Switching and Routing forum where it has received a couple of responses. Now you post the same question on a different forum - and without any acknowledgement that it duplicates a previous question. I would suggest that any further discussion of this question should be consolidated on the forum that you chose originally.
Rick
Rick
