ISDN - Spid 2 (Await Establishment)
jasonrandolph
I have a number of Cisco 2811 routers at various remote locations. Every one of them experiences this same issue. I have upgraded IOS twice on them to no avail.
Upon router boot, SPID1 establishes but SPID2 stays in Awaiting Establishment.
Example:
Global ISDN Switchtype = basic-ni
ISDN BRI0/1/0 interface
dsl 2, interface ISDN Switchtype = basic-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 88, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI 88, ces = 1, state = 8(established)
spid1 configured, spid1 sent, spid1 valid
Endpoint ID Info: epsf = 0, usid = 0, tid = B
TEI Not Assigned, ces = 2, state = 3(await establishment)
spid2 configured, spid2 NOT sent, spid2 NOT valid
Layer 3 Status:
0 Active Layer 3 Call(s)
CCB:callid=0, sapi=0, ces=2, B-chan=0, calltype=INTERNAL (BR0/1/0) SPC C all
Active dsl 2 CCBs = 1
The Free Channel Mask: 0x80000003
If I shut the BRI interface, clear the module, and un shut it, the 2nd spid established without issue.
Example:
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 89, Ces = 2, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI 89, ces = 2, state = 5(init)
spid2 configured, spid2 sent, spid2 valid
Endpoint ID Info: epsf = 0, usid = 1, tid = B
Layer 3 Status:
Active dsl 2 CCBs = 0
Total Allocated ISDN CCBs = 0
Current software revision is:
c2800nm-advipservicesk9-mz.124-13b.bin
Any suggestions of where to look next? It doesn't matter who the ISDN carrier is, they all do this at boot.
jasonrandolph
Correction, I had to clear the interface on this particular router twice in order to establish the 2nd SPID
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI 89, ces = 2, state = 8(established)
Layer 3 Status:
You are running into this bug. Workaround options are listed at the bottom.
CSCsf04593 Bug Details
2nd SPID always stays INVALID until sh/no shut on the bri interface
Basic Description :
When a known working ISDN BRI line is plugged into a router, the
2nd SPID always stays INVALID as shown by "show isdn status" :
As a result only one (the first) B channel can make/receive calls.
Conditions:
The problem is not seen if you are running some 12.3 code instead of
12.4.
Symptoms:
-Similar to CSCsa87703.
-However, the problem is seen on both the version 2 (WIC-1B-U-V2) and old
version 1 cards (NM-xB-U).
Workaround:
-Configure "isdn twait-disable" under the BRI interface, or
-Enable isdn q921/q931 debugs. Enabling the isdn debugs and doing a shut/
no shut on the BRI makes the 2nd SPID goes valid (just as it was in
CSCsa87703), or
-Downgrade to 12.3
Sundar
