03-21-2005 11:25 PM - edited 03-03-2019 09:06 AM
How load balancing performed in ISIS with 7 routers with same multi-area 1-7? Any idea or URL would be highly appreciated.
Best Regards
03-23-2005 02:22 PM
Enter maximum-path 8 within ISIS configuration. It will support up to 8 paths per router.
Is that what you meant by 7 routers? or 7 interfaces? If per router, need to describe the links and interfaces each router has.
Log in to Community
