ISIS Loopback configuration
For a Level-2 only IS-IS network (multi-topology IPv4 and IPv6)
What is the difference between using passive-interface for the loopbacks, or assigning the isis process to the loopbacks
example for ios
router isis AREATAG
  passive-interface loopback 0
  isis metric 1 level-2
  isis ipv6 metric 1 level-2
versus
  ip router isis AREATAG
  ipv6 router isis AREATAG
Can I assume these are equivalent?  Loopbacks would not create adjacencies in any case.
For a network with Level1 areas would these be different?
Are there relative best practices?
balaji.bandi
when you configure passive interface, the interface configure will be removed and no hellos will be sent out.
BB
>From my understanding - hellos are not sent from loopbacks in any case
