Routing
Labels
 Hi, i would need some help with proof of concept. We have 2 sites and we want to use QINQ. We want the Provider to be the one adding and removing the outer tag. So for ingress, the Provider add the outer tag ex 4000 and before it sends it out egress...
Tuff by Level 1
  • 226 Views
  • 2 replies
Good day team\collegues!Today I've upgraded cisco C8300-1N1S-6T to 17.15.4cIt has been deployed on 29th September https://software.cisco.com/download/home/286324476/type/282046477/release/IOSXE-17.15.4cI've converted to INSTALL mode and next is to in...
s_SiD_s by Level 1
  • 749 Views
  • 14 replies
Hi team,  Besides the WAN ports on the IR8340/K9 device, the LAN ports also support routing (can operate at Layer 3). Thanks team
HatDauNho by Level 1
  • 216 Views
  • 7 replies
I have one Router Cisco Serie 2500 Model 2511. This device cannot boot. If someone has the iOS image to recover it. Please can you give me the solution or where I can download the image IOS to recover my Router Cisco Model 2511 Serie 2500, or any sol...
leo814 by Community Member
  • 160 Views
  • 2 replies
Hello all,Suppose I have 2 routers directly connected on a routed link, and these 2 routers are OSPF neighbors. Since the link is a routed link, I don't want any DR/BDR election to take place and waste time. To avoid a DR/BDR election, I believe I ca...
vv0bbLeS by Level 3
  • 309 Views
  • 6 replies
Hi, we recently purchased catalyst 8500 router, if we don't use DNA service, does 8500 need to communicate with smart license? The license transport type is CSLU. Below is the output of the command "sh license status". Can someone pls advise, thanks ...
we have a cat 8000v on all cloud hyperscalers. how can we especially troubleshoot cpu performance of the device? license throughput is far enough, but the forwarding of the packets seems to be limited. but how can we get to the bottom here? there is ...
I know this is not a putty forum, but I thought that some of you may be using this. I am trying to use Putty pscp to transfer files to and from my routers. I can pull files from the router with no problem. When I try to push a file to the router, it ...
holt0202 by Level 1
  • 16454 Views
  • 9 replies
  • 1 Helpful votes
hi,I have two routers that are part of asymtric connection toward exernal partner. Sometimes traffic from one sesion goes over one router and returnes over another and that is fine. I have monitor capture session that captures some traffic and becaus...
Someone asked me what does protocol field 0 indicates in IP header?? It's confusing since protocol field only indicates upper layer protocol and 0 is used for IP Right??
