ISR 892SFP
Bernardo_c
Hi ! Someone can give me some hints about configuration of this ISR? I have a 1905 working fine in my internet using PPPoE and since this 892 have two WAN interfaces I'm thinking to use it as link fail over, but even in a single link I can't configure it !
I'm tried to create interface Dialer for PPPoE in the Gig0 or Gig9 and don't work. Also in the lan, DHCP server only on VLAN1 interface..it's a different behaviour compared with my 1800/1905 router.
Where can I learn the differences / "modus operandi" of this router?
Any help are appreciated
Bernardo
2 Accepted Solutions
glad that you got it resolved.
The virtual access interface is part of the PPPoE client session. Check the link below (item 4) for an explanation.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/bbdsl/configuration/xe-16-6/bba-xe-16-6-book/bba-pppoe-client-xe.html
Tks seems it's a new feature. The old 1800/1900 routers don't have it..
I have two PPPoE links, I will configure the second interface and will try link failover ;0) as next challenge!
Bernardo
12 Replies 12
post the running configuration (sh run) of the router, so we can fill in the (missing) bits and pieces...
Bernardo_c
Hi Georg, tks for your reply:
I have an Cisco 1905 now, using this script in my home:
version 15.0
service password-encryption
hostname Bernardo
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp pool LAN
network 172.16.18.0 255.255.255.0
default-router 172.16.18.1
dns-server 8.8.8.8 8.8.4.4
ip domain name Wirelesstech.biz
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip ddns update method NOIP
HTTP
add http://charnisb:aaaaaaa@dynupdate.no-ip.com/nic/updatehostname=&myip=
interval minimum 0 0 5 0
vpdn enable
vpdn-group 1
request-dialin
protocol l2tp
license udi pid CISCO1905/K9 sn FTX162184N1
interface GigabitEthernet0/0
description INTERFACE CONEXAO LAN
ip address 172.16.18.1 255.2...
sorry for the confusion: what I meant was: post the running configuration (sh run) of your 892SFP router...
Georg, I cleared all the configurations on the 892SFP. I'm not copying again the 1905 script to the 892SFP. See the environment:
ADSL2+ Modem (PPPoE) directly connected to the interface G9 of the 892.
My notebook (LAN) directly connected to the interface G0 of the 892.
See the ShRun of 892SFP:
There's some errors in the middle or the print since the router it's up and connected to the ADSL Modem - see was created Virtual-Access2
892-Bernardo#sh run
Building configuration...
Current configuration : 3027 bytes
! Last configuration change at 19:10:22 UTC Mon Apr 5 2021
version 15.5
hostname 892-Bernardo
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip dhcp pool LAN
HTTP
add http://charnisb:aaaaaa@dynupdate.no-ip.com/nic/updatehostname=&myip=
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
request-dialin
protocol l2tp
license udi pid C892FSP-K9 sn FJC2206L10E
description INTERFACE CONEXAO MODEM ADSL
no ip add...
I am not sure what the issue is...the configurations you post are truncated and incomplete. If posting the full running config here does not work, save the output of 'sh run' to a text file, and add that text file as an attachment...
Georg, thanks for your patience!
Let's go back to my first question. Since my need it's quite simple, ignore the script since may be wrong - I'm beginner - and help me to configure from zero.
I need only two things: In the Gig0 - LAN with DHCP Server and in the interface Gig9 - WAN with PPPoE and of course the ACL and NAT as usual. I did it on my 1905 (I'm using it now) but seems the same script don't work on the 892SFP. If you wish I can provide an unattended remote access using a local PC.
Bernard
I am not sure I understand what your topology is supposed to look like. Either way, try the config below. I think the WAN interface is GigabitEthernet0, though:
no service pad
hostname 892SFP
boot-start-marker
boot-end-marker
enable secret 5 $1$g4y5$NxDeM.0hON6YA51bcfGvN1
enable password ciscocisco
no aaa new-model
ip routing
ip cef
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 4.2.2.2
no ip address
ip nat outside
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip nat inside
interface Dialer 1
ip address negotiated
ip nat outside
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
dialer-list 1 protocol ip permit
ip nat inside source list 1 interface Dialer 1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 192.168.1.0 0.0.0.255
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
login
transport input telnet ssh
end
It's missing the line with PPP authentication.
The WAN interface it's G9 (it's defined by the hardware, G8 and G9 as WAN) and G0-G7 (LAN - in a small 8-port switch)
I added the PPPoE authentication lines, and changed the WAN to G9 inteface.
The DHCP it's ok (as I made first, using the VLAN1 interface, not G0)
The PPPoE dialer are not ok, showing this error :
*Apr 6 00:17:47.091: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Apr 6 00:17:47.095: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Apr 6 00:17:50.375: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Apr 6 00:17:50.379: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Apr 6 00:18:12.439: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Apr 6 00:18:12.443: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Apr 6 00:18:15.695: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Apr 6 00:18:15.699: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Apr 6 00:18:37.783: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Apr 6 00:18:37.791: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Apr 6 00:18:41.251: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Apr 6 00:18:41.255: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
Show Run as below:
no service pad
hostname 892SFP
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
ip cef
ip dhcp pool LAN
interface GigabitEthernet9
no ip address
ip nat outside
interface Vlan1
ip nat inside
interface Dialer 1
ip nat outside
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname guest@guest
ppp chap password guest
ppp pap sent-username guest@guest password guest
ip classless
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
login
end
try the config below, if that still does not work, tun
no service pad
hostname 892SFP
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
ip cef
ip dhcp pool LAN
no ip address
ip nat outside
interface Vlan1
ip nat inside
interface Dialer 1
ip nat outside
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
--> ppp ipcp route default
--> ppp ipcp dns request
--> ppp ipcp address accept
ip classless
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
login
end
Bernardo_c
Hi Georg!
The dialer error was solved. I used debug ppp negotiating and discovered that's username error. The ISP changed it removing the @guest
Now, the PPPoE it's ok but I still not understand what is the Virtual-Access1 and Virtual-Access2 created .
I need to learn more about this 892SFP IOS - it's quite different than the 1800/1900/2600 series
Thanks for your patience and help !!!
I may close this topic for now.
Bernardo
