Beginner
ISR G2 - support for WIC-1T and WIC-2T
I wonder if legacy WIC-1T and WIC-2T will be supported on ISR G2 (c2900 and c3900) in EHWIC slots.
I received an error message upon c2921 boot up
*Feb  2 14:08:25.107: %MAINBOARD-1-UNKNOWN_WIC: wic card in location 0/0 has an
unknown id 0x2
and  "show diag" displays
Slot 0:
        C2921 Mother board 3GE, integrated VPN and 4W Port adapter, 7 ports
        Port adapter is analyzed
        Port adapter insertion time 00:02:58 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC14010GAD
        Hardware Revision        : 1.0
        Part Number              : 73-11835-03
        Top Assy. Part Number    : 800-30794-01
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2921/K9
        Version Identifier       : V01
        CLEI Code                : COMGL00ARA
        Processor type           : C2
        Chassis Serial Number    : FCZ140371P4
        Chassis MAC Address      : 8843.e148.9a50
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        WIC Slot 0:
        Serial 1T WAN daughter card
        WIC module not supported/disabled in this slot
        Hardware revision 1.1           Board revision E0
        Serial number     10536228      Part number    73-1775-02
        FRU Part Number     WIC-1T=
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
        EEPROM contents (hex):
          0x20: 01 02 01 01 00 A0 C5 24 49 06 EF 02 00 00 00 00
          0x30: 70 00 00 00 98 10 22 01 FF FF FF FF FF FF FF FF
Everyone's tags (5)
1 REPLY 1
Advisor
Re: ISR G2 - support for WIC-1T and WIC-2T
It looks like it is not supported. Here's a link to the support cards. The WIC-1T and 2T are not listed. You can upgrade to the HWIC-1T and 2T though.
http://www.cisco.com/en/US/products/ps10537/products_relevant_interfaces_and_modules.html#serialwan
Hope that helps.
Content for Community-Ad
August's Community Spotlight Awards
