05-15-2020 11:19 AM
What I am trying to do is upload the new IOS to the router.
I have done this before on a ISR4321 when using TFTPD64 on my computer.
I am a complete beginner and I am not sure what other options I have to get the IOS uploaded to the router.
I connect a console cable and a network cable between the router and PC.
I have two different ip addresses in the same subnet.
I can ping the router from the pc and vice versa.
Since I am unable to configure VRF I am not sure how to continue because without it I am not sure how I can use TFTP.
On the ISR4321 I could use this command on the interface: vrf forwarding Mgmt-intf
When I use this command on the router I get this result:
Solved! Go to Solution.
05-15-2020 01:07 PM
You do not need VRF interface for the Upgrade to Copy image to router
As you mentioned You can reach each other "I can ping the router from the pc and vice versa."
I believe your PC running TFTP Server, Copy the image to Root folder of TFTP Server.
Copy using IP to copy
Stil you looking for VRF, you need to create VRF interface first then put the interface in to VRF later
05-15-2020 01:07 PM
