ISR1117
I'm trying to locate the SKU for the ISR1117 power supply and connector.
luis_cordova
Hi @EddieRodriguez9237
According to the datasheet, by default 66W is used, but if you connect devices with PoE, then you need 115W.
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
PWR-66W-AC=
PWR-115W-AC=
