ISR4331-SEC - Extended warranty -for additional modules (SM-X-6X1G, NIM-2CE1T1-PRI)
Vladimir_B
I want to buy ISR4331-SEC router with additional modules - SM-X module with 6-port dual-mode GE / SFP and 2 port Multiflex Trunk Voice/Channelized Data T1/E1 Module.
I know that ISR4331-SEC router have 90-days standard warranty. Specialists from IT company propose me - SNTC-8X5XNBD Cisco ISR 4331 Sec bundle w/SEC license for one year service.
My question - Will SNTC-8X5XNBD cover ISR4331-SEC router with additional modules or he will cover only ISR4331-SEC router? And i need to find additional service packages to cover additional modules ?
Thanks in advance,
Best Regards,
Vladimir
Mark Malone
the mods are usually covered under the chassis unless purchased at a separate time to the 4331 , if so the serial may need to be added to the 4331 contract so its covered under the chassis itself , that how our vars do it , then its all under 1 unit supported , if they dont do that you may have altering supporting dates for the mods and the chassis
