ISR4400 ROMMON
So I don't know if its just me but I can't seem to get to ROMMON on my 4400 Series ISR 4451. I have literally tried everything cycling power
ctr+break, power cycle ctrl+shift+6,
power cycle baud rate 1200 and space bar for 10-15 sec. I'm not sure if I am missing my window or what but I can't seem to get to it. Wish it was simple as the Catalyst switches that come with a mode button. Any suggestions of things to try would be nice if any
Couldn't get to the boot log due to the console cable being locked down. But I was able to finally get it by going to edit on securecrt and sending the break versus trying to use the keyboard thanks!
9 Replies 9
balaji.bandi
sure what terminal client you using : (try break keys)  baud default 9600
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/troubleshooting/guide/isr4400trbl/isr4400trbl02.html
Can you also post complete boot logs, may be it disabled password recovery - we dont know.
BB
 I'm using SecureCRT and I can't even get to boot logs console wise it's locked down which is why I am trying to get to ROMMON mode to do a password recovery. It set racked for years and no one remembers the password or username to get into it.
Connect the console cable right port ( check the port mentioned as console)
Console Port Handling Overview
If you are using the console port to access the router, you are automatically directed to the Cisco IOS command-line interface (CLI).
If you are trying to access the router through the console port and send a break signal
 (by entering Ctrl-C or Ctrl-Shift-6, or by entering the send break
command at the Telnet prompt) before connecting to the CLI, you are directed to a diagnostic mode if the non-RPIOS subpackages are accessible. These settings can be changed by configuring a transport map for the console port and applying that transport map to the console interface.
BB
Yes the settings for the serial connection are as depicted. As I stated I have used all these methods and it still loads as normal and prompts me for a username and password which I obviously don't have.
Good you followed all, but you missed this was asked before :
BB
is this means you able to break key get in to change the password ?
BB
Glad to know you able to make it work, we make now as resolved now.
BB
