This below text is being displayed on my ISR 4431 and then not starting at all. So what i would like to know is if possible to perform hardware reset on it. I learned that 4331 does have a reset button at the back of the device but it seems like the ISR 4431 version does not have reset button on the outside or visibly. I was wondering if there is a work around for this like if the reset button is inside the dev
▒▒▒▒▒▒^C▒V▒▒▒%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 5 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 6 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 7 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 8 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 9 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 10 contained errors which were auto-corrected.
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): prep_storage took: 15 seconds, expected max time 10 seconds
%IOSXEBOOT-2-FLASH_SIZE_CHECK: (rp/0): Flash capacity (15 GB) is insufficient for fault analysis based on installed memory of RP (16 GB)
%IOSXEBOOT-2-FLASH_SIZE_CHECK: (rp/0): Please increase the size of installed flash to at least 16 GB (same as physical memory size)
%IOSXEBOOT-4-BOOT_SRC: (rp/0): mounting /boot/super.iso to /tmp/sw/isos
[UPDATE] It worked and boot was fine after I changed the baud rate to 115200. All these worked though right after I reloaded the router except this time, I accessed it with a different baud rate. update is incase someone else run in to a similar issue and desparately thinking of way to reset their router.
已解决! 转到解答。
- Check it these errors are persistent after reload,
M.
M.
I reloaded alot of times and they are incredibly persistent and the same time after time.
Hello @iscoFe_2021 ,
try to start the device in ROMMON
Power Off the device and connect the Console cable use CTRL+BREAK to get in ROMMON
https://community.cisco.com/t5/routing/think-i-ve-bricked-an-isr-4331/td-p/3888622?dtid=osscdc000283
it looks like the IOS image is somewhat corrupted so use the suggestions in the thread above to delete the file and to copy on an USB drive a valid IOS image.
Hope to help
Giuseppe
It worked but with a different baudrate right after reload. Thanks!
Below is how the entire boot process looks
▒▒f▒!p▒▒C▒D▒
Checking for PCIe device presence...done
0▒o2▒▒▒؟▒9▒▒▒▒▒▒▒C▒kk&▒g▒▒
▒▒(▒d▒²▒O&▒▒1▒▒L
▒▒▒C▒▒3 ~▒
▒▒!▒!▒▒▒▒▒wRq▒▒o▒▒F▒Jj
3▒w>▒θ▒▒
▒▒Vo▒▒C?▒▒x▒L▒▒▒o▒▒▒?▒▒▒!▒$▒▒!▒C▒!wH▒a''▒H▒▒▒O▒▒!▒C▒c▒▒▒▒▒▒▒▒p!▒▒k")▒C/!+)▒▒
h▒▒▒▒!▒▒/읟▒֕mH.Hى▒▒/▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒9▒C!!s*{!)▒!▒C#g▒̔0èJH,
▒r▒▒߽l1▒▒▒ݝ▒▒▒▒Sl1▒d▒▒▒k.▒ݚ▒▒
.@▒▒_0▒▒BlM
p▒!▒▒▒▒▒▒▒!▒L /▒L*JB
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): prep_storage took: 14 seconds, expected max time 10 seconds
w▒!▒▒▒▒!▒k▒▒K*▒▒V▒ ▒)!▒ć▒8▒▒k▒▒g▒▒w▒!ݘ!▒▒▒L▒▒^!▒
▒▒/▒▒1 ▒▒8{▒▒HH▒▒▒L▒V!▒▒!ͨ▒l▒J▒a▒▒▒▒^!▒
▒1▒vF▒rB8▒▒>"▒▒▒+!!▒▒9▒▒*▒.H▒▒r)▒▒▒ ֙
H(!▒▒▒1O"!!!!! ▒!H▒֮▒lH▒H▒▒'''s)▒▒▒▒K& ▒▒C2ʊ▒▒▒ހ▒▒▒▒
▒▒XLL, ▒▒▒▒▒▒CJ▒
▒X̪▒jH▒!▒J▒▒1▒▒▒▒^Cb1▒▒-▒▒▒▒▒▒▒ ֙▒ܞ▒
▒▒9▒H▒▒K▒▒▒1▒▒L
z▒▒▒▒▒▒ ֹ
▒C+s&)▒▒▒#▒▒▒▒▒▒*O*!k▒▒▒▒▒C\▒C*▒▒)▒▒▒C▒Xh▒▒▒▒▒▒s1!1îȾϽ▒▒▒▒▒N▒▒▒▒1▒`▒▒▒szC▒!
!▒▒▒▒w▒▒C/▒▒!)▒ى▒C!▒▒ި▒▒ć1C▒!▒▒!1!▒▒ި▒▒os▒#▒▒ s▒▒▒▒s"=▒▒▒▒0▒▒▒▒▒3▒▒9▒!▒▒w*▒ןtc▒▒b▒▒蘾▒ s!▒!▒܇!▒)▒▒9▒▒▒▒ s▒▒ ▒!▒!▒)▒
ى▒!/s▒#0)▒▒▒▒s▒d9▒!▒▒DC/▒▒O▒▒Fى▒C!▒▒▒▒+▒▒▒!▒▒!▒▒'▒9x▒▒▒G
▒▒N▒▒▒▒J=s▒J▒▒=!▒K!=x▒▒▒▒▒▒C?!s&)!▒!▒▒▒/▒!▒!▒▒;g▒o1▒
▒▒▒▒▒9x▒
뜍▒▒9▒1)▒!H▒!▒▒▒▒ʌ▒
▒▒9▒▒!)▒▒▒+ )! ▒H▒▒vbs{f▒▒▒▒
▒▒F▒ޘ䯝1▒▒▒▒!nC=▒▒߽▒▒ޞ▒
▒N▒▒Cn▒▒▒▒▒▒▒▒▒kν▒▒K▒1Cf▒▒▒BH'▒▒▒(▒戾▒▒b▒▒▒▒!!▒8▒▒▒s▒ġ▒▒▒▒▒
9▒▒)▒▒▒1▒▒▒▒▒▒▒Vb▒▒▒▒!▒▒8▒▒▒s▒D▒▒▒▒▒▒
9▒▒>▒sR@▒▒�▒Vb▒▒▒▒!!▒8▒▒▒s▒ġ▒▒▒
9▒▒ΈsV@▒▒�▒Vb▒▒▒▒!▒▒8?▒▒s▒D▒▒▒▒▒▒
9▒▒▒o▒▒
BBB▒k!8▒▒▒s▒D▒▒▒▒▒▒!1{o9;99BBBBBB
▒N▒Vb▒▒▒▒!!▒8▒▒▒s▒ij▒▒▒▒gg'{o9;99BBBBBB
▒N▒▒b▒▒▒!!▒8?▒▒s▒ij▒▒▒▒gg7{o9{99BBBBBB
▒▒▒Vb▒▒▒▒!▒▒8▒▒▒s▒D▒▒▒▒▒▒gg{o9;99@BBBBB
▒N▒▒b▒▒▒!!▒8?▒▒s▒ij▒▒▒▒o▒Nʈ! ▒
▒▒▒Vb▒▒▒▒!!▒8▒▒▒s▒D▒▒▒▒▒▒
▒N▒▒▒9▒▒▒
▒s▒! k▒▒▒▒! ▒
؟▒N▒p▒▒▒{v▒▒▒N▒H▒J▒Jk▒▒▒0f9▒▒C9▒▒̌Nf▒▒▒▒o▒N▒▒k1!▒
▒H▒J▒▒▒K8 ▒c?▒M▒c▒▒▒▒!▒k6{ x▒J▒▒▒H▒J▒J▒Jʈ▒▒#▒▒▒▒!▒w▒▒▒▒▒+sևv91▒k▒▒^▒D@k▒▒▒▒▒▒▒)▒s▒▒▒▒▒H▒߅▒Ba!!▒▒/▒ߝD▒H▒J▒J▒i▒▒▒▒▒▒▒▒▒s▒ޘ▒D@k▒▒▒▒▒▒)▒s▒▒▒▒▒▒▒▒▒h▒▒▒H▒▒▒▒
▒H▒ZJ▒f▒▒▒
▒k/▒▒▒k/▒▒VB▒k*߾▒▒G▒▒JH▒Z▒NJ▒֘
▒▒J▒JNJ▒֘*▒▒▒kv▒C▒▒
▒▒J▒JNJ▒֘)▒/ß▒▒▒▒
▒H▒Z▒▒֘▒'g7{o9+1)▒/ß▒▒=▒▒
▒▒\f▒▒▒C▒
▒▒J▒z▒j▒\▒
▒H▒Z▒*▒▒▒s▒▒▒!!魉▒▒c!▒x▒J▒▒▒PH▒J▒9▒H▒▒▒▒▒L▒▒▒▒k许o̯▒▒▒k~▒X
▒▒\꽈▒▒9▒▒▒s'! ▒URCo#!!▒=▒▒JH▒Z▒*▒▒▒s▒▒
▒H▒Z▒▒▒▒▒s▒!1▒▒▒▒▒kv▒C▒▒
▒▒J▒Z▒▒▒s▒▒▒!▒PH▒▒kv▒C▒▒
▒▒▒Ⱦ▒9▒▒▒sg! gg{o9+1)▒/ß▒▒=▒▒J▒JZ▒*▒▒▒s▒▒
▒HJ▒▒▒N▒L▒L▒▒gS6!▒▒9▒▒▒o▒▒kj9H▒Z▒▒▒x
▒H▒*▒▒▒͘ݽ▒▒99▒L▒H▒J▒9▒Hz0▒脦
▒▒▒ވ▒▒9OB▒H▒J▒9▒H
▒؈NL▒
JH▒Z▒9▒9▒▒X̢▒=H▒wReab▒Gnk▒▒k)ܽ▒:▒▒J▒▒ZZ9▒9▒▒֊Ľ
▒M8▒▒▒▒▒▒▒:▒▒t▒@▒H▒J▒9▒
▒֊Ľ
▒▒▒▒:▒nd▒D▒H▒J▒9"▒H▒F▒▒▒sS▒▒H▒▒
▒H▒Z▒9▒H▒▒▒▒�=▒H▒D▒ƭ▒▒3S▒▒B▒ȭݽ▒
▒▒▒sk&▒▒▒:▒▒▒H▒Z▒9▒▒▒0▒▒▒
0▒o*w▒k▒)▒▒▒▒K ▒▒C2ʪ▒▒▒▒▒▒▒▒▒
▒▒XlL, ▒▒▒▒▒CJ▒
▒c▒V▒▒▒:J▒▒▒1▒▒▒\▒^Cb1▒▒LH
▒H▒Z▒9▒H▒n▒▒▒▒▒M▒k▒k▒\▒▒▒▒▒!▒#k*▒wReab]w▒!▒
▒HJZZ9HHz▒L▒▒▒\n▒!dOBH▒J▒9▒0
▒H▒Z▒▒▒h▒▒▒o▒s1▒▒▒.Έ▒▒▒{▒7)9ȝ▒▒▒
d▒▒skH)H▒J▒
▒H▒Z▒▒▒{▒▒t▒!@!▒▒▒̆DB▒▒fM▒Hoȧ▒\▒D
▒J▒Jd!▒J▒
h▒q▒▒▒'▒▒9▒▒<)▒g3
▒H▒ZJ▒uH▒
▒J▒Jd!▒▒▒▒'1;!▒kHgC!1S!▒wz6▒▒(▒▒▒D▒H▒J▒9▒
▒H▒ZJ▒usB▒▒+▒))W"▒▒▒
▒H▒Z▒*[H▒▒X̆▒▒3S▒▒!▒▒
JH▒Z▒*▒K8▒ ▒▒@▒▒▒▒+)▒▒▒▒
▒▒B▒▒▒▒▒▒S▒X▒
JH▒Z▒▒ ▒▒▒'k"▒▒▒▒▒!▒nC▒ˌ
JH▒Z▒*▒▒֘!▒▒▒Gn▒▒▒▒!):▒
▒▒f▒▒▒▒gg7{o9;991)▒oß▒▒=▒▒J▒J▒▒*▒J▒▒▒▒▒MX▒sg! g'{/9#991)▒/ß▒▒=▒▒J▒JZ▒*▒9▒▒̊▒M▒▒s▒! gg{o9+991)▒oß▒▒=▒▒J▒J▒Z▒[▒֘
▒f▒▒▒▒gg'{o9;991)▒/ß▒▒=▒▒J▒J▒ڕ▒▒▒▒
▒▒f▒▒▒▒'g7{/9#991)▒oß▒▒▒J▒J▒ڕ
▒▒\f▒▒▒▒▒gg{o9;991)▒oß▒▒=▒▒J▒J▒Z▒J▒▒▒
▒f▒▒▒▒▒!1{o9;991)▒oß▒▒=▒▒J▒J▒Z▒j▒8ސO
▒H▒Z▒*▒eB>▒
D▒\▒▒▒
1▒▒▒▒▒9▒▒9▒▒▒▒@▒▒m1F
▒▒F
▒H▒Z▒▒▒HO▒▒F
▒H▒Z▒*!▒▒ސO
JH▒Z▒*OC▒kC▒▒
D▒▒▒▒
▒9▒oL▒▒L:▒▒J▒J▒Z▒)▒O
▒H▒Z▒*)▒▒▒▒▒=▒▒▒9▒
▒▒L▒OB▒H▒J▒9)▒▒▒
o▒{▒▒▒▒▒?▒O▒▒▒▒▒▒̽▒▒OB▒H▒J▒9)▒▒▒
D▒▒s▒▒▒▒▒=▒▒J▒J▒Z9
▒H▒j▒9!▒▒▒▒▒▒▒▒6▒▒B▒ȭ▒▒k)ܽ▒▒!▒▒͘
!):▒0)!▒▒▒▒▒g▒▒▒▒▒▒#Ν▒▒▒
J▒J▒Z)Hk▒Ľ
▒▒of▒▒▒sBr▒Rr▒▒
It looks like something is not making sense for the router internal system.
This is irrelevant but i already tried to console from different PCs. Do you think hardware reset is possible for this Router, that was what i was looking to find out.
