Hi,All! I was performing ISSU on 7606 following this document:
After the first step (issu loadversion) i've spotted the problem, standby supervisor moved to "cold standby" state, although it was expected "hot standby":
My redundancy configururation:
core-7606-01#sh run | sec redundancy
redundancy
main-cpu
auto-sync running-config
mode sso
core-7606-01#show redundancy
Redundant System Information :
Available system uptime = 44 weeks, 2 days, 6 hours, 12 minutes
Switchovers system experienced = 0
Standby failures = 3
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = sso
Operating Redundancy Mode = rpr
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 5
Current Software state = ACTIVE
Uptime in current state = 44 weeks, 2 days, 6 hours, 12 minutes
Image Version = Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRD, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 23-Oct-08 17:55 by prod_rel_team
BOOT = bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRD.bin,12
CONFIG_FILE =
BOOTLDR =
Configuration register = 0x2102
Peer Processor Information :
Standby Location = slot 6
Current Software state = STANDBY COLD
Uptime in current state = 23 minutes
Image Version = Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Feb-10 01:06 by prod_rel_team
BOOT = bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRD4.bin,12;bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRD.bin,12
CONFIG_FILE =
BOOTLDR =
core-7606-01#sh redundancy states
my state = 13 -ACTIVE
peer state = 4 -STANDBY COLD
Mode = Duplex
Unit = Primary
Unit ID = 5
Redundancy Mode (Operational) = rpr
Redundancy Mode (Configured) = sso
Redundancy State = rpr
Communications = Up
client count = 128
client_notification_TMR = 30000 milliseconds
keep_alive TMR = 9000 milliseconds
keep_alive count = 1
keep_alive threshold = 18
RF debug mask = 0x0
After issu loadversion bootvar looks as following:
core-7606-01#sh bootvar
BOOT variable = bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRD.bin,12
CONFIG_FILE variable =
BOOTLDR variable =
Standby BOOT variable = bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRD4.bin,12;bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRD.bin,12
Standby CONFIG_FILE variable =
Standby BOOTLDR variable =
Standby Configuration register is 0x2102
So my question is what to do next? I can't run "issu runversion" because downtime will follow I think.
Solved! Go to Solution.
Hi Eugene,
it seems that you don't have finished the ISSU upgrade completely.
Sup on slot 6 runs SRD4, I suppose the new image you want to run, while the one on slot 5 runs SRD (which I suppose is the original image).
Considering that the now active Sup in slot 5 "Uptime in current state = 44 weeks, 2 days, 6 hours, 12 minutes" while the one on slot 6 "Uptime in current state = 23 minutes" I think you forgot the final reload of one sup.
If you don't remember at which stage you are force switchover will let you failover to the sup on slot 6 while the one on slot 5 will reload on SRD4. You need to make sure that the bootvariable points to the correct image first, right now slot 5 still points to SRD.
Riccardo
You could try setting the boot variable of the active supervisor to be the same as for the standby and then reboot the standby again. Currently you are in RPR mode which usually means that there is a difference in the configurations of the two supervisors.
Adrian
Hi Eugene,
Riccardo
Actually we was required to configure "issu image-version comp disable". After that standby supervisor became "hot standby" and ISSU was finished correctly without downtime.
