08-21-2011 12:43 PM - edited 03-04-2019 01:20 PM
I'm having issue in redistributing eigrp in to bgp. please check attached file.
I'm redistributing 10.10.1.0/24 into BGP from eigrp as show in the attached file. but the routes aren't advertized.
please help!
08-21-2011 01:07 PM
They are not appearing in rtr A rib ? did you configure next-hop-self on rtr B? verify they are known as EIGRP routes in B with show ip route eigrp and they are redistributed with sh ip bgp.
Then see if they are in rtr A BGP table and if there is not a > sign before the prefix then do a sh ip bgp
Regards.
Alain.
08-21-2011 01:28 PM
Router B:
I did "sh ip bgp" and saw all these static routes with "s>" at the beginning.
router A:
don't see these routes in the routing table.
please help
08-21-2011 01:45 PM
hi,
It means they are suppressed because of the summary-only keyword in the aggregate command.
You should see the summary advertised to A and installed in the routing table of A.
Regards.
Alain.
08-21-2011 06:45 PM
Hey mate few things to check:
- as above stated verify that you have no auto summary enabled in EIGRP
- redo your route-map and access-list like:
route-map EIGRP-BGP permit 10
match ip address REDISTRIBUTION
set metric 102400 1 255 1 1500
ip access-list extended REDISTRIBUTION
permit ip 10.10.1.0.0 0.0.0.255 any
Cheers,
Fabio
08-21-2011 11:57 PM
Hi Fabio,
I don't thinj BGP will understand this metric, don't forget he is redistributing from EIGRP into BGP.
If auto-summary was on in EIGRP then B would receive the summary(/8) and not the individual prefixes and so these wouldn't match the ACL and there wouldn't be any redistribution into BGP.
Can Gavin post the following outputs on B :
-sh ip ro eigrp
-sh ip bgp | i 10
-sh run | s bgp
Regards.
Alain.
08-22-2011 04:29 PM
Hi Alain,
You are definately right. I pasted the wrong part of my config.... thanks for pointing that out...
I only mentioned metric because i have come accross situations where the routing table would no redistribute unless specifying a metric...
