Issue of the port channel in Cisco ASR1001x router
mmendis
We are using a port channel for our up streaming router (Cisco ASR1001x) and there is a problem after configuring the port channel of it. We used GigabitEthernet0 / 0/0 and GigabitEthernet0 / 0/1 to create that port channel. But there is no Rx traffic from GigabitEthernet0 / 0/1. Please refer the details below which we obtained from the router and advise on this matter.
Metro-ASR1001x[1.22]#sho interfaces  description
Interface                      Status         Protocol Description
Te0/0/0                        up             up
Te0/0/1                        up             up
Gi0/0/0                        up             up
Gi0/0/1                        up             up
Gi0/0/2                        up             up       SLT-Primary | CCT:84780D |portchannel 2
Gi0/0/3                        up             up       SLT-Primary | CCT:84780D |portchannel 2
Gi0/0/4                        up             up
Gi0/0/5                        up             up       Uplink | 1.0 Range
Gi0                            down           down
Lo0                            up             up
Lo2                            up             up
Lo4                            up             up
Lo6                            up             up
Po1                            up             up       description SLT-Primary | CCT:84854D
Po2                            up             up       SLT-Backup | CCT:84780D
Po3                            down           down     testing
Po4                            up             up       Uplink | 1.0 Range - Direct
Metro-ASR1001x[1.22]#sho interfaces summary
 *: interface is up
 IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
 OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
 RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
 TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
 TRTL: throttle count
  Interface                   IHQ       IQD       OHQ       OQD      RXBS      RXPS      TXBS      TXPS      TRTL
* Te0/0/0                       0         0         0         0 168857000     38989 303370000     43847         0
* Te0/0/1                       0         0         0         0 137828000     35863 354735000     50295         0
* GigabitEthernet0/0/0          0         0         0         0 740410000    104881 102048000     32885         0
* GigabitEthernet0/0/1          0         0         0         0         0         0 162382000     36417         0
* GigabitEthernet0/0/2          0         0         0         0      7000         8         0         0         0
* GigabitEthernet0/0/3          0         0         0         0      6000         7         0         0         0
* GigabitEthernet0/0/4          0         0         0         0     21000        28     21000        28         0
* GigabitEthernet0/0/5          0       132         0         0  12763000      1807  82439000     10952         0
  GigabitEthernet0              0         0         0         0         0         0         0         0         0
* Loopback0                     0         0         0         0         0         0         0         0         0
* Loopback2                     0         0         0         0         0         0         0         0         0
* Loopback4                     0         0         0         0         0         0         0         0         0
* Loopback6                     0         0         0         0         0         0         0         0         0
* Port-channel1                 0         0         0         0 740410000    104881 264430000     69302         0
* Port-channel2                 0         0         0         0     13000        15         0         0         0
  Port-channel3                 0         0         0         0         0         0         0         0         0
* Port-channel4                 0         0         0         0 306685000     74852 658105000     94142         0
Metro-ASR1001x[1.22]#sho etherchannel summary
Flags:  D - down        P/bndl - bundled in port-channel
        I - stand-alone s/susp - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 4
Number of aggregators:           4
Group  Port-channel  Protocol    Ports
1       Po1(RU)         LACP     Gi0/0/0(bndl) Gi0/0/1(bndl)
2       Po2(RU)         LACP     Gi0/0/2(bndl) Gi0/0/3(bndl)
3       Po3(RD)
4       Po4(RU)         LACP     Te0/0/0(bndl) Te0/0/1(bndl)
RU - L3 port-channel UP State
SU - L2 port-channel UP state
P/bndl -  Bundled
S/susp  - Suspended
6 Replies 6
Leo Laohoo
And the problem is what, exactly?
The port channel did now work properly.When the traffic transferring process only one port is work(Gi0/0/0) but the other port(Gi0/0/1) did not get the traffic through it.Please find the following details of  the show interfaces summary.
 *: interface is up
Other side of etherchannel use wrong hash making all traffic flow through one port not load balance between port.
balaji.bandi
how is your Loadbalance configuration done.
I do below steps to verify : when you get chance and maintenance window to test.
1. check the Physical cables if any one having issue.
2. you can shutdown the active link see other traffic able to pass using the other interface.
3. check the load-balance config of etherchannel - show etherchannel load-balance
ASR by default do Flow based, if you looking VLAN based you need to look below config guide :
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asr1000-software-config-guide/evc-port-chann-asr.html
4. post below output
show run interface gi0/0/0
show run interface gi0/0/1
show  interface gi0/0/0
show  interface gi0/0/1
show  run interface po1
BB
can be a load balance method misconfiguration. check below guide.
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/xe-16-12/asr1000-software-config-guide-16-12/evc-port-chann-asr.html
Good luck
KB
network51
What equipment do you have on the other end of this port channel and what is the port channel config on the other end ?
