Issue with BRI dialup
rockb1212
I am configuring a BRI dialup.
Everything works fine when I test locally dialing from one SPID to the other but when I try to dial anything else I get:
00:57:37: BR0/3/0 DDR: Dialing cause ip (s=XXX.XXX.XXX.XXX, d=XXX.XXX.XXX.XXX)
00:57:37: BR0/3/0 DDR: Attempting to dial XXXXXXXXXXX
00:57:38: BRI0/3/0: wait for isdn carrier timeout, call id=0x804A
00:57:38: DDR: Dialing failed, 1 packets unqueued and discarded
00:57:43: BR0/3/0 DDR: rotor dialout [best] least recent failure is also most recent failure
00:57:43: BR0/3/0 DDR: rotor dialout [best] also has most recent failure
BRI and dialer configurations:
interface BRI0/3/0
no ip address
encapsulation ppp
dialer pool-member 2
isdn switch-type basic-ni
isdn point-to-point-setup
isdn spid1 XXXXXXXXXX
ppp authentication chap
interface Dialer1
ip address XXX.XXX.XXX.XXX 255.255.255.252
encapsulation ppp
ip summary-address eigrp 50 XXX.XXX.XXX.XXX 255.255.255.128
dialer pool 2
dialer idle-timeout 600
dialer string XXXXXXXXXXX
dialer hold-queue 100
dialer-group 2
peer default ip address XXX.XXX.XXX.XXX
fair-queue 64 32 0
Richard Burts
Can you run debug for ISDN Q931 while you attempt the call and post the output?
Rick
Rick
Debug for ISDN Q931 below
00:51:28: ISDN BR0/3/0 Q931: Sending SETUP  callref = 0x0001 callID = 0x8001 switch = basic-ni interface = User
00:51:28: ISDN BR0/3/0 Q931: TX -> SETUP pd = 8  callref = 0x01
    Bearer Capability i = 0x8890
        Standard = CCITT
        Transfer Capability = Unrestricted Digital
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0x83
        Preferred, Any B-channel
    Keypad Facility i = 'XXXXXXXXXXX'
00:51:28: ISDN BR0/3/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x81
    Channel ID i = 0x89
        Exclusive, B1
    Locking Shift to Codeset 5
    Codeset 5 IE 0x2A  i = 0x80880B, 'XXXXXXXXXXX', 0x800109800114800114800114
00:51:29: ISDN BR0/3/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x81
    Cause i = 0x82C1 - Bearer capability not implemented
00:51:29: ISDN BR0/3/0 Q931: TX -> RELEASE pd = 8  callref = 0x01
00:51:29: ISDN BR0/3/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x81
Thanks for providing the debug output. I believe that it does help us understand the issue. The key item is this line
When I look up the code 0x82C1 I find this explanation:
The network cannot provide the bearer capability that the user                requests.              Contact the telco to troubleshoot further.
So it looks to me like the ISDN circuit is not provisioned the way that you think it is. You should check with your provider about how the circuit is set up.
Rick
Rick
