Issue with redistributing from bgp into eigrp using route map
carl_townshend
Hi All
I'm having an issue with redistributing from bgp into eigrp using route map and prefix list
I have vrf's on the router
If I remove the route map redistribution seems to work.
All the ip addresses in the prefix lists are present in the bgp table
config below
router eigrp 101
 address-family ipv4 vrf TEST
  redistribute bgp 64550 metric 1 10 255 1 1500
  network x.x.x.x 0.0.0.0
  passive-interface default
  no passive-interface GigabitEthernet0/1
  autonomous-system 101
 exit-address-family
 bfd all-interfaces
router bgp 64550
 bgp router-id x.x.x.x
 bgp log-neighbor-changes
 no bgp default ipv4-unicast
  redistribute eigrp 101 route-map EIGRP>BGP
  neighbor x.x.x.x remote-as 5555
  neighbor x.x.x.x timers 10 30
  neighbor x.x.x.x activate
  neighbor x.x.x.x send-community extended
  neighbor x.x.x.x soft-reconfiguration inbound
 exit-address-family
ip prefix-list TEST seq 1 permit 10.30.108.0/24
ip prefix-list TEST seq 2 permit 10.30.14.0/23
ip prefix-list TEST seq 3 permit 192.168.114.0/23
route-map BGP>EIGRP permit 10
 match ip address prefix-list TEST
Any ideas?
Julio E. Moisa
You could include this command in BGP: bgp redistribute-internal, the iBGP learned routes are not advertised to the IGP via redistribution so you can add that command. Although as I remember the iBGP learned routes are not usually redistributed into an IGP it could be a solution.
Also I suggest this metric in EIGRP redistribution:  redistribute bgp 64550 metric 100000 10 255 1 1500
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
5 Replies 5
Julio E. Moisa
The thing is, there are no issues with the redistribution, it works.
But as soon as I apply the route map it doesn't work, even though the prefixes are learned in bgp
any ideas?
What is the route-map applied into EIGRP?
router eigrp 101
Are you matching the correct subnet mask known into the BGP table?
the route map is BGP>EIGRP
It has actually working now, I changed the metric to the one you suggested and wella!!
How come the seed metric I put in didn't work?
cheers for your help
You are welcome  :-)
Actually I have seen situation where the metric 1 1 1 1 1 is configured and that is not good because that is not representing real metrics.
