IWAN compatibility on Cisco platforms.
Folks,
What would be the limitations to run IWAN on the Cisco 3945/3925 routers as compared to the Cisco 4xxx routers?
I understand that the Cisco 3945/3925 can only run at the Branch office but what other than that?
Thanks!!
N.
royalblues
Level 10
Level 10
No specific limitation apart from the throughput of the platforms
If you are using APIC-EM for iWAN provisioning then the ISRG2's (3900's) are supported only from 1.2 .
the earlier versions of APIC-EM doesn't support them to provision as branch routers
