IWAN
j44mistry
Does anyone know if IWAN is supported on Cisco 3925 Routers ?
Charles Hill
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Intelligent_WAN/release/notes/iwanrn.pdf
Hardware and Software Requirements
Cisco IWAN, Release 2.0, supports the following Cisco platforms and software releases.
Device
Cisco IOS Software Release
Hub/Remote Site
Cisco ISR 4000 Series Routers
Cisco IOS XE 3.14 or higher.
Hub or remote site.
Cisco ASR 1000 Series Routers
Hub site.
Cisco CSR 1000v Series Routers
Hub site (Master Controller only).
Cisco ISR-G2 Series Routers
Cisco IOS 15.5(1)T1 or higher Cisco IOS 15.4(3)M1 or higher.
Remote site.
Charles Hill
Device
Hub/Remote Site
Hub or remote site.
Hub site.
Remote site.
Yes, but careful of the throughput limitations. We were advised that this platform would support around 25mbps but I thinkis much lower in reality. Especially critical if you're going to run waas/wccp as this is done in software in iwan template. If you can, move up to isr4k where these limitations go away. Hth
