Jitter 10ms
mdargin
What is an acceptable Jitter Rate for an SLA with a service provider?
MY provider is saying that they will guarantee that jitter will not go
above 10 milliseconds and it will be measured in 5 minute intervals.
This is an MPLS network and we will run IP voice over this network.
What amount of Jitter can cause voice communication problems? Is it 8
milliseconds?
Thank You for any responses, all responses are greatly appreciated.
Have a wonderful day.
paolo bevilacqua
That depends also by the endpoints you are using. eg the cisco router and telephones can tolerate jitter also of 20 - 30 msec quite well.
blatkinson
If you know your jitter will be consistent and low, you can set a static jitter buffer on the endpoints. Cisco says their dynamic jitter buffers are good at adjusting the buffer but if you know your jitter limits already you can go with a static buffer as the dynamic buffer is always going to add a little "wiggle room" so it can adapt just in case there is a deviation from the trend.
Here are a few references that can help you:
http://www.futurehardware.in/339875.htm
http://www.ciscopress.com/articles/article.asp?p=606583&seqNum=2
Please rate if this helps.
http://www.juniper.net/solutions/literature/white_papers/mpls_private.pdf
The ITU (International Telecommunication Union) recommends that the one-way, end-toend
delay associated with a voice call does not exceed 150 ms. In addition, jitter should not exceed 40 ms and packet loss
should not exceed 0.5%.
HTH - pls rate all useful posts
