Kindly put this error in the Error Decoder
ryel.dsouza
   Kindly put this into the Cisco error decoder and let me know what is the output because i don't have access to the decoder "Bad RAM at location 0xA0000000: wrote 0xA0000000, read 0xA0000200"
Ryel
David Aicher
this isn't really a traceback to be decoded.
"Bad RAM at location" is telling you that the ram failed POST test or some other online diagnostic.  These errors are typically fatal and cause the router to reload.  You will need to replace the ram or possibly the chassis/motherboard.
Dave
