Hello everybody,
Here is the situation - I want to establish l2tpv3 tunnel between two 800 series boxes. However the situation is that on one end I have DHCP configured on WAN interface and fixed IP address can't be configured.
Will the tunnel work if I configure xconnect only on the router with the DHCP IP on WAN pointing to the router with the static IP while omitting xconnect command on the router's config with the static IP?
Thanks.
