Join Customer Connection to register!
249
KATTUBAVA E.S
Beginner
L2VPN behavior with different VC type
Hi Experts,
I wanted to know about L2VPN functionality with below scenarios., What will be the behaviour of PE1 and PE2 when CE1 is tagged/untagged with different VC type configured.
Topology:
CE1-------PE1-------LSP---------PE2------CE2
Scenario 1: If CE1 has no vlan tag and VC-Type is Raw Mode
Scenario 2: If CE1 has no vlan tag and VC-Type is Tagged Mode
Scenario 3: If CE1 has vlan tag (10) and VC-Type is Raw Mode
Scenario 4: If CE1 has vlan tag (10) and VC-Type is Tagged Mode
-bava
2 REPLIES 2
KATTUBAVA E.S
Beginner
Can someone help me on this?
-bava
Julio E. Moisa
VIP Mentor
Basically you must have the same configuration on both ends otherwise it will not work, also if you are configuring EoMPLS you must specify the VLAN on the client side as well.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
