Join Customer Connection to register!
242
cisco_lad2004
Contributor
L2VPN EVC manipulation
Dear all,
I am looking at the following design challenge:
CE1-SWITCH-PE1-(VPLS cloud)-PE2-CE2
CE1 to switch is a trunk with 5 different VLANs(12, 13, 14, 15, 16), switch encapsulates the 5 vlans using 802.1ad into vlan 100.
PE(XR based), matches on 802.1ad vlan 100, and then add S-TAG 20.
What can I do on PE2(XR) to be able to present CE2 with a trunk where I can match on CE1's 5 original VLANs ?
Since I can match with outer and inner vlans, I cannot use encapsulation 20 12 for example, as the 2nd tag is 802.1ad vlan 100. My aim is to be able to match upper/outer tag (S-TAG) and customer VLANs (3rd inner) bypassing 2nd tag :-)
Any suggestions ?
0 REPLIES 0
