L3 switch
anitachoi3
I have two options to re-design the office (create 5 vlans).
1. router + ethernet switch (26xx + Dlink)
2. L3 switch, cisco CAT 35xx only (not cisco router)
which one is better? we will have 300 - 350 user within 3 years.
rgds
we have around 220 users.
2 Accepted Solutions
paolo bevilacqua
If it was only VLAN, sol. 2 is better.
But, in reality you always need a router to connect to internet, firwall, VPN, Voip, all things that only a router does.
So in practice you need both a good switch and a good router. For example, one 2800 router, one 3750 L3 switch, as many more CE-500 switches (because they have PoE for when you put the IP phones).
Anita
You can use static routes on the 2800 or you can use a dynamic routing protocol such as EIGRP/OSPF to exhange routes between the 2 devices.
To connect the router to the 3750 it would make sense to use a L3 connection.
So on the 3750 under the interface you are connecting to the router
3750(config-if)#no switchport
3750(config-if)#ip address 172.16.1.2 255.255.255.252
3750(config-if)# no shut
On the 2800 router that connects to the switch
int fa0
ip address 172.16.1.1 255.255.255.252
The rest of the cat 3750 config is creating the vlans at Layer 2 and then creating the L3 interfaces
3750(config)# vlan 10
3750(config)# int vlan 10
3750(config-if)# ip address 172.16.2.1 255.255.255.0
you need to do this for each of your vlans. Note that until as least one port is active in the vlan the L3 vlan interface will stay down.
Jon
5 Replies 5
Danilo Dy
If its just a LAN (no WAN), I recommend option 2.
Dandy
paolo bevilacqua
Richard Burts
Anita
There are some factors which might affect the design which you have not addressed in this post that could influence the design- for example is there a requirement for connectivity outside the office. But based on what you have provided so far I would advise the choice to use a Cisco layer 3 switch rather than a Cisco router connected to non-Cisco switch. If the primary routing activity is going to be inter-vlan routing then the layer 3 switch is a more effective solution than the router. With the router solution the frame must pass over the link from switch to router and then back over the same link from router to switch. Where with the layer 3 switch the frame arrives on one virtual interface and is routed out the other virtual interface.
Rick
Rick
Thanks all, we may order cisco 28xx and csico 37xx.
If the vlan traffic goes through L3 switch, the router (28xx) should not be config 802.1q. am i right? I such config 5 static routes point to CAT 37xx.
the config should be:
R1:
interface FastEthernet0
ip address 172.16.1.11 255.255.255.0
ip nat inside
ip route 172.16.2.0 255.255.255.0
ip route 172.16.3.0 255.255.255.0
ip route 172.16.4.0 255.255.255.0
ip route 172.16.5.0 255.255.255.0
Interface FastEthernet1
ip address 209.x.x.x 255.255.255.252
ip nat outside
ip nat pool office 209.x.x.x 209.x.x.x netmask 255.255.255.252
ip nat inside source 10 interface FastEthernet1 overload
access-list 10 permit 172.16.0.0 0.0.7.255
what is the CAT 3700 config?
Rgds
Anita
int fa0
Jon
