09-25-2013 03:30 AM - edited 03-04-2019 09:08 PM
hello experts,
currently I have the interconnection between 2 braches through using L3 VPN, and now I want to make it redundant by adding E1 point-to-point connection. I have a correct & stable configuration for the L3 VPN, what is the required configuration for the E1 to be adding to the router? my router is Cisco 2921 series.
much appreciate your advice and feedback.
best regards,
09-25-2013 03:45 AM
Hi Hardi,
Does the E1 connect back to hub site? If yes, you can increase the metric on the E1 interface to make it less prefer from routing protocol that you run.
HTH,
Lei Tian
09-25-2013 04:16 AM
hello Lei,
I think will I have a long discussion with you regarding this issue if you don't mind?
is there any resources to help me out in this implementation?
Best regards,
09-25-2013 04:23 AM
Hi Hardi,
Send me email if you want.
HTH,
Lei Tian
