Lab for my ccent
Niteowl1970
I am going to try my best to explain the issue that I am having in a lab that I setup. I am adding a screenshot of my lab simulated in packet tracer. I am using IP helper-address commands on all routers so that it passes dhcp commands to my gateway router (labeled ISP) that is giving out IP's. Routers NSSLab01, NSSLab02 and NSSLab05 have no problems pinging the gateway and the computers connected to those routers are pulling the correct ip's from the prospective pools. Once I go more than 2 deep in the router stack, down to NSSLab03 and NSSLab04 I can no longer ping the ISP router or the core switch (switch9). I can however ping all ports on NSSLab01 and I can ping over to NSSLab05 from the bottom 2 routers. I am assuming that EIGRP is allowing me to ping all of the cisco 2911's? However the ISP router is a business class router that brighthouse provided, it can do RIP and RIPvs but not EIGRP. I have setup RIPv2 on all routers, but still cannot ping the ISP router from the bottom 2 routers. Its got me puzzled because the bottom 2 roouters can ping up to NSSLab01 but not past it, while NSSLab02 can ping everything and its in the same stack. Here is a screen shot from packet tracer and below that is the config for NSSLab03.
NSSLab03#show running
Building configuration...
Current configuration : 949 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname NSSLab03
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524TL62
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 10.10.5.1 255.255.255.0
ip helper-address 10.10.0.1
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.10.4.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 10.10.6.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router eigrp 100
network 10.10.4.0 0.0.0.255
network 10.10.5.0 0.0.0.255
network 10.10.6.0 0.0.0.255
router rip
network 10.0.0.0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
dukenuk96
Level 3
Level 3
Please share all the configs of all devices in your lab - better attach the whole PT project file, we'll try to find the issue. NSSLab03 is not enough to find the problem, but one thing to think about:
router eigrp 100
router rip
network 10.0.0.0
You are running two different protocols for the same networks - what do you want ot achieve doing so?
I am running both protocols because not all devices in the network support EIGRP. I will that file uploaded asap.
