LAB Scenario - Eigrp
tomfree_leo
Hello
LAB Scenario - Eigrp Load Balancing on unequal Bandwidth
LAB Diagram attach
Can I get correct steps to enable load balancing on unequal bandwidth
Tom
5 Replies 5
Giuseppe Larosa
Hello Tom,
first of all the worse path must satisfy the fesibility condition advertised distance < Feasible distance
in your case this is fine because both links are to the same router.
EIGRP metric is directly proportional to cumulative delay and inversely proportional to lowest bandwidth on path
256 * (sum of delays in tens of microseconds) + 256 * ( 10^7 / minBw [kbps])
you can use sh ip eigrp topology to see advertised distance and distance calculated on local node
the command to be used under router eigrp process is
variance M
the calculated distance on local node for the backup path has to be less then M the feasible distance (best metric to IP prefix on local node)
in your case M can be calculated as the ratio of bandwidths on the two links
1544 / 256  = 6,034
I would use M = 7 in your case to be sure that secondaryt path will be used
if delay is the same on the two serial interfaces you can check this with
sh interface s0.1
sh interface s0.3
you need to use the above command on both routers Earhart and Cochran under router eigrp process
if delay is different the ratio can be greater between the two metric values.
Hope to help
Giuseppe
Hi Guislar for perfect explanation
which is practically more stable per session or per link loadbalancing. what configuration is needed for per session loadbalancing & per link loadbalancing
Thanks for your help
Tom
Hello Tom,
per packet load balancing is not recommended it can cause out of order
default CEF flow based is enabled by default
to enable per packet CEF load balancing in interface mode
interface type x/y
ip load-sharing per-packet
note: not all platforms support it.
you should be fine with CEF flow based that makes the exor of IP SA, IP DA and an hash
Hope to help
Giuseppe
Thank you  Giuseppe
Have a look at the attached design.
its simpler having one edge router but how do switch forward packets equally on both edge router connecting to remote Router.
Next Lab its redistribution,
OSPF between L3Switch & Edge Router
EIGRP between Edge Router and Remote Router
This is complex, how can help to understand.
cheers
Tom
Hello Tom,
if you are using EIGRP the same rules described in first post applies to this scenario to the EIGRP domain.
edge routers should talk both EIGRP and OSPF and to redistribute between them
EIGRP requires the setting of a seed metric using metric components
OSPF requires the use of subnet keyword
on both edge routers
router ospf 10
red eigrp 100 subnets type 1
router eigrp
red ospf 10
default-metric 10000 1000 255 1 1500
! seed BW, delay, reliability, MTU and load
In real world you would consider to use OSPF everywhere and to leave slower link as a backup path.
safer and simpler to troubleshoot
Hope to help
Giuseppe
