LACP on FEX Ports
visitor68
Level 5
Level 5
Does the 22xx Series FEX support static or dynamic LAGs between itself and a server?
Imagine a server with dual 10G NICs, and I need to connect them to the SAME 22xx  FEX....can I set up a LAG between the two 10G NIC ports and two 22xx  FEX Host ports? Does it depend on how the FEX is connected to the parent  55xx?
cflory
You did not mention which 22XX you have in your possession, there seemed to be a limitation with 2148's:
https://supportforums.cisco.com/thread/2001757
This discussion seemed to have ended with the recommendation to purchase a 2248T.  As I have not actually tried this configuration, as there hasn't been a need (at least in my environment) as yet.  I'd be interested to grab a free 2248T and try it out.
